'old' SanDisk SATA 5000 SSD's
Dalfo002
Does anyone happen to know whether these older SSD's from samsung are SLC or MLC? I see them listed as industrial SSD's and they are mounted in aluminum casings, but i cannot find any real specifications on them. It is almost as if SanDisk has disavowed all knowledge of ever having manufactured them. I was thinking of picking up a few used ones for some relatively harsh environments but i want to know what i am actually buying.
looking at the 32GB SDS5C
http://media.digikey.com/pdf/Data Sheets/M-Systems Inc PDFs/SSD_SATA_5000_2.5_DS_Rev0.2.pdf
That's the whole shebang on that series of drives. The basic info on that drive isn't all that impressive, I hope you are getting them really cheap!
 High capacity in small form factor
o 2.5" small form factor supporting unformatted capacity of 4, 8, 16, 32, 64GB
o 9.5mm case height
o SATA 7+15 pins combo connector
 Interface to host
o Standards: SATA 1.0a 1.5Gb/s
 High performance
o Host transfer rate: 150MB/s
o Internal transfer read rate: 67MB/s
o Internal transfer write rate: 47MB/s
o Random Read (4KB): 5400 IOPS
o Average access time: 0.11msec
 Low power consumption
o Supply voltage: 5Vdc
o Typical read: 210mA
o Typical write: 220mA
wow, thanks for the quick reply. I really need to work on my search skills apparently.
