Ok quick question for all you PSU guru's out there.
I currently have a (about 5 yr old) Antec True 430 PSU (not v2.0) and I was wondering if this would be able to work with either the AsRock DualSATAII or and Abit KN8-SLI(though I will not be using SLI). It is a standard 20pin with the 4pin 12v. I am assuming that this will work with the AsRock but will not with the Abit. I only plan to run an 3800+ and 7600GS with this system as the main powerhouse parts.
This is the spec sheet for the PSU, alas mine does not have the SATA connector though.
http://www.antec.com/specs/true430_spe.html
Thanks for your help.
