Old Fashioned Case
Scratch99
Really need some guidance.
Looking for a case to house a new build/old build.
Asus P5K motherboard, Core 2 Duo, with good old XP Home.
Looking for something that mounts the power supply at the top end of the case instead of on the floor. (what I'm used to)
Budget $50.00 to $110.00
Don't need no glass or lights. :)
Just need this and to choose a power supply.
Appreciate any and all remarks.
Thank you.
Scratch...
Scratch99
Many thanks Pendragon.
The first two show a 350W power supply included.
This may be a little light for my needs.
Looking at a Rosewell for $60. Has the power supply mounting on the bottom.
May have to change my thinking on this.
pendragon1
there are "lots" of the old school style still out there. they are usually lower end brands or designed for builders putting together office systems.
Scratch99
Thanks Pendragon.
I need to do a bit more searching.
Have to make a decision soon.
Found one on the "bay" for cheap. :)
