Old Creative X-FI Elite Pro
TechLarry
RIP [H] Brother - June 1, 2022
I still have one of these sitting in the junk room. It worked when put away.
This thing was VERY expensive when new (Like $400) and was Creatives high-end audiophile solution. It has a PCI card and an big ass external box with connectors for days.
Specs below.
My question is, based on the specs, is this something I should use instead of the SB Z card I now have? Believe it or not there are Windows 10 drivers. They really have done well in supporting this kit.
Hardware features::
· Creative X-Fi Processor based solution
· 116dB SNR DAC Quality on all channels
· 136dB SNR Internal Audio Processing Quality
· 64MB X-RAM (Xtreme Fidelity RAM)
· THX Certified Quality
· Extended I/O via Internal Drive-Bay Module
· IR Remote
Connectivity::
PCI-card
· FlexiJack (Performing a 3-in-1 function, Digital In / Line In / Microphone) via 3.5mm mini-jack
· Line level out (Front / Rear / Center / Subwoofer / Rear Center) via 3 X 3.5mm mini jacks
· AUX_IN line-level analog input via 4-pin Molex connector
· 26 pin AD_Link connector for linking to the X-Fi I/O Console (upgrade option)
Console
· Two RCA jacks for coaxial SPDIF input and output
· Shared Auxiliary input/Phono input via RCA stereo jacks
· Two optical connectors for optical SPDIF input and output
· Two standard MIDI female connectors for MIDI input and output
· Headphone output and volume control via 6.35 mm (1/4-inch) stereo jack
· Shared line-level analog Line/Microphone input via 6.35 mm (1/4-inch) stereo jack
· Shared line-level analog Line/Hi-Z input via 6.35 mm (1/4-inch) stereo jack
· DIN jack to connect Creative analog speaker systems with the wired remote control or Audio Control Pod that comes with the speakers
· One AD_LINK connector for linking to the audio card
Technical specifications:
· 24-bit Analog-to-Digital conversion of analog inputs at 96kHz sample rate
· 24-bit Digital-to-Analog conversion of digital sources at 96kHz to analog 7.1 speaker output
· 24-bit Digital-to-Analog conversion of stereo digital sources at 192kHz to stereo output
· 16-bit to 24-bit recording sampling rates: 8, 11.025, 16, 22.05, 24, 32, 44.1, 48 and 96kHz
· Signal-to-Noise Ratio (20kHz Low-pass filter, A-Weighted)
- Stereo Output 116dB
- Front and Rear Channels 116dB
- Center, Subwoofer and Side Channels 116dB
· Total Harmonic Distortion + Noise at 1kHz (20kHz Low-pass fi lter) = 0.004%
· Frequency Response (-3dB, 24-bit/96kHz input ) = <10Hz to 46kHz
· Frequency Response (-3dB, 24-bit/192kHz input) = <10Hz to 88kHz (Stereo only)
· ASIO 2.0 support at 16-bit/44.1kHz, 16-bit/48kHz, 24-bit/44.1kHz 24-bit/48kHz and 24-bit/96kHz with direct monitoring
· Enhanced SoundFont support at up to 24-bit resolution
Contents of the retail box:
· Sound Blaster X-Fi Elite Pro PCI Card
· X-Fi I/O Console
· Remote Control
· 2x Batteries (AA)
· Rubber Foot (x4)
· Vertical Stands
· 3.50 mm (1/8-inch) to 6.35 mm (1/4-inch) plug adapter
· Power Splitter Cable
· Volume Control Cable (9-pin DIN)
· AD_Link Cable
· X-Fi Music Applications CDs
- Cubase LE
- WaveLab Lite
- Amplitube LE
· Quick Start Leaflet
· Installation and Applications CD containing:
- Drivers for Windows® XP
- Creative Software Suite
- Doom 3 Sound Blaster EAX patch
- User's Guide
Recommended price:
· 3695 SEK
Toppen av sidan
I would certainly give it a try. Personally I prefer the X-Fi cards over the Sound-Blaster Z line. This card that you have is about the best X-Fi you can get aside from the Titanium HD.
The specs look good to me. Since there's drivers and if you've got the slot, definitely try it.
The Elite Pros are great, one of Creative's all time great cards. Unless you have a specific reason, I'd keep using it.
I think I'll give it a try.
I think the Z cards are down on dynamic range, and while the USB DAC built into my Line-6 AmpliFi TT box improves that a lot, it's output section is very noisy from a white noise standpoint.
One of these days I'll just get a box of Schiit :)
The only thing the Z series is better at is directional sound. My 2.1 puts sounds damn near 360 degress around me and even does vertical levels well for gaming. Otherwise, they do not sound as good. Especially for music. It is really disappointing for music.
I would look into the DanielK drivers. They seem to work great with Windows 10. I rotate between my XFi Titanium and my ZXR for diferent games.
