Santa Claus
- Nov 10, 2008
Hi, bought a sata addon pci controller card earlier this week but the computer refuses to boot with it.
I can boot with the card installed and drivers loads and the card works according to windows.
But as soon as i attach a harddrive it stops working, hangs during bootup with a black screen.
I can enter boot menu(F8) but it hangs as soon as i chose either normal bootup or safemode.
SDM PCI SATA RAID 2P (SiL3512) http://www.speeddragon.com/index.php?controller=Default&action=ProductInfo&Id=38
The Moterhboard is a nforce2-based K7n2G-L
The psu is a 420w chieftec
30gb + 46gb Ibm deathstar Pata
160gb + 320gb Seagate barracuda Sata-II
I can boot with both ibm and a cd-reader but not with 1pata and 1sata and cd-burner disconnected so dont think its a power issue.
I have tried to jumper the 160gb seagate to Sata-I but no change.
Can a harddrive be moved from a Intel P965/ICH8R Sata-II controller to the SDM PCI SATA RAID 2P without any need to reformat the harddrive?
What else can cause the computer to hang as soon as windows starts loading?
Regards
Regards
