Old case where PSU goes right over CPU
pookguy88
I have an older ATX case where the PSU is kind of mounted directly over the CPU (P4 mobo) when you lay the case down on it's side. (i.e. it is not above the CPU when you stand the case upright). Is it ok if such a PSU is the type where there are two fans on each end of it (instead of one big one on the bottom)? I ask because I'm afraid i'm suffocating the CPU this way.
Any advice is appreciated, thanks
BTW, this box will not be doing heavy duty work if that matters.
You'll be fine. The primary function of the PSU fan is to cool the PSU, not your processor. That's what a heatsink is for.
