i have an old a7m266 with an amd xp 1900+ i am using the 1006 bios and i have problems every time i want to shut the system down or restart it. the problem is that the system will either lock up and fail to post or if it does post the cpu settings are reset to default. at which point i have the change the settings in the bios and power down the system and turn it on again several times before it will post properly. some times its take more then one "bios reset" in this manner before the board will post at the proper speed. i actually own more then 1 of these boards in working condition and have several friends with the same board and they all have the same problem with both athlon xp and athlon thunderbird chips.
