Old artic silver, Big Typhoon
justin82
Can artic silver get old? also when you install a big typhoon how tight do you tighten the screws? (my bracket is tight enough where it is bent slightly) and do you have any tips on tightening it down its a bitch with those fins in the way.
i only play with mine when i have the mobo out of the case.
to make it easier you could use some wing nuts.
