Old 9800PRO 256MB problem
Matthew Kane
Hey all, my old 9800PRO has a problem now and its been so long since I've tested/used it.
The problem is that its got a floppy drive power connector and once I plug in the power connector it, a message on the screen says that I need to plug in the power plug into the power connector on the 9800PRO. The problem is that I already have the plug plugged into it. The gfx card is a Powercolor 128Bit R350 256MB 9800Pro card and I'd love to get it to use again asap for my newly built refurbished server. Thanks.
Power circuit on the card might be fried or a pin in the socket might be bent/crushed. Either way the card isn't "seeing" the connected voltage.
enable side band addressing (aka SBA) on your motherboard :D
okay, i am messing around, sry mate cant resist, LOL.
Nah no bent pins in the socket tried the card in 3 different agp motherboards, same message still. And no theirs nothing wrong with the floppy cable, but I am starting to think I need a decent psu to power it up again, will that help?
it is most likely that either the power traces have been damaged some way or; whatever device that registers the voltage off of the connector is faulty.
you can try pushing down firmly on the connector's PCB side or even maybe using a little solder... you break it any more than it is and unless you have a very old and low powered PSU then it should be enough to get past the boot message.
well I did use a generic 300watt psu...would that be the problem?
NOTE: I don't have any good psu's lying around the house atm.
