OK, whats wrong with my CRT
MYSTic Jedi
Well, i just got home today, turned on my monitor (17 in. flat screen CRT from compaq, ~2 years old) and it was all yellow, so i just thought something magnetic had been near it, so i did the Degause thing, but that didnt work, so i was like oh crap, im gonna have to buy a new monitor, but then when i was moving it around, it went away, good as new, or so i thought. So now it flashes back and forth between 3 different shades (Clean and clear, light yellow, and a dark yellow color) randomly. So what do you guys think could be causing this? Has somthing come loose in the tube, is my color filter thing going out, or something else? Please help!, because i realy dont have the money to buy a new monitor at the moment. Thanks so much!
As far as I know you shouldn't move a CRT when it's on or 'shortly' after when it's still hot.
Seems weird to me that it flashes between different colors. But that yellow-problem could have been caused by the VGA-cable coming loose. Try to reconnect them (both on the monitor and PC) and screw them on.
its somewhere between a loose cable , a faulty solder joint (good luck finding it thought) and a failing yellow gun (most likely)
see if you can get a new moniter just to make sure its not the vid card (highly unlikely)
thore
thore
Agreed except for the yellow gun part (there is no yellow gun actually) ..most likely the Blue gun isnt working which would only leave Red and Green (mix red + green = yellow). if replacing the cable doesnt fix it (assuming its detachable) then looks like its time for a new monitor :(
Also when its yellow try wacking the side of the monitor ..if it returns to normal or flickers between normal & yellow then its most likely a dried up solder joint.
GreenMonkey said:
In my experience this problem is generally the VGA cable.
Well, dang, the cable on my monitor is unatchable! Gosh, i hate cheap monitors...............*sigh*
