Ok what in the heck? Need Help Please....
Moose777
Specs are as follows:
AMD 64 3500+
Asus A8N SLi Premium
2 Gig Corsair Valuselect Ram
eVGA 7800GTx
SB Audigy ZS Plat Pro
I played F.E.A.R. for about an hour today. Had absolutely no problems with it.
I put the computer in Standby for a few hours while I cleaned up my office. I DID NOT TOUCH anything that had to do with the computer. Not that it would matter anyway.
So then I decide to play NFS: MW. I boot the computer out of Standby.
It boots but the screen never comes on. So, I reboot. The screen comes on it posts then it gets to the PCI Device Listing Screed and it locks up with some weird error thing on the bottom of the screen except it doesn't say anything. The keyboard is also deader than a doorknob.
Here's what I'm getting.
-|Be_$-|Be$
But above the (e) is a little mark you kind of see it above the letter (N) in Spanish.
What the fuck does this mean?
I swear I've had nothing but problems with this Asus board since I installed it.
Whats even more f'd up is that if I go intot he BIOS and reset the defaults (not that I've even changed anything since installing this board) it goes back to working.
The longer I own this board the more I think it's defective because it does some really bizzare shit.
Not to mention that none of my fans seem to go over 1800 rpm and that bothers the shit out of me too.
The Audigy line of cards and their lovely drivers have issues with asus utilities among other things just an FYI.
Not sure about your problems but it's not running hot? What all did you install?
Well as soon as I turn the computer on I get the overheat alarm but it's as soon as I push the power button so I can't see how it's running hot as soon as I turn the rig on.
The alarm goes off almost immediately.
The other thing that bothers me too is that I have the external box and remote controll for my Audigy 2 and the remote control has never worked. I've even reinstalled the drivers.
I would check the bios for your temp settings and see if thresholds are enabled or too low to remove that alarm. I have them disabled so the bios won't alarm me or take action. If that doesn't work I would defintely make sure everything is seated properly heat sink fans are running everything.
The Audigy beta drivers I had caused many utilities to not install or function such as fan/temp monitoring and in general I had some odd issues in windows. It took me all day to narrow it down to that card and the drivers but I didn't have any external drives that you can get with the Creative gear. This was during initial install of drivers and utilities though so I don't know for sure what else it would have affected thank god.
What bios revision do you have? Make sure you have 1009 the beta (1011) I hear mixed reviews that it works fine but breaks alot of the overclocking features or settings. If your on 1009 already try resetting to defaults and running everything on auto when possible to gauge stability. If by some miracle that works go back and edit your bios settings that you want like removing unnecessary features such as USB floppy etc etc. What about your ram timings? Did you set those manually? Try setting that to auto most of the time 2t is best with cheaper ram and that doesn't always work either so 3t it is. You can also try setting the ram to ddr333 instead of 400. Oh and check the manual and see if you have the ram in the dual channel slots or single channel try switching it around and checking.
You stated that resetting to defaults let's it work or post and boot into windows? Now let me ask you a question in this regard do you have the AI booster or ntune installed? If yes uninstall this stuff immediately then reboot go into your bios and make sure you don't have the auto overclock feature enabled. The reason I ask this is because I noticed installing the windows overclocking utilities somehow changed my bios settings (probably upon reboot not sure) so everytime I went back into the bios to troubleshoot a shutdown on error issue it was set to an auto overclock. Ntune didn't help either for some reason and caused problems even without the AI NOS overclock utility installed in my case.
When I installed the board I left everything as was set by Asus. I am runnin 1009 the newest Bios; although when I boot it says BIOS version 5.1.39 (so who knows, I know it was updated when I installed it). I've tried uninstalling the Audigy and reinstalling it several times and once in a while it does this. As far as I know everything is seated correctly. I'll check again. I know all my fans are spinning but at what speed is beyond me. I'm using an Sunbeamtech Chromatic Windmill fan controller (it too was giving me problems), it's technically not connected to anything in Windows. It just has some leads for the fans and a few temp leads. In fact I have an RMA for it since it doesn't keep any settings but I haven't gotten around to sending it back yet.
Memory timings are set to whatever the factory has them set at. I haven't messed around with anything on this board as it's been very, very unstable from the get-go.
Yes, when I go into the BIOS and set everything to default it will post normally, boot into Windows and acts as if nothing had happened. Ai Booster is didsabled as is Ntune. Auto overclock as far as I know is also disabled.
If I change anything in the BIOS it will not post. I just tried. I have to set everything to Default and it'll boot. Memory is set at 333mhz timings are at 2T (I have no 3T option that I can see).
yeah, what he said!
On a related note, did you plug in the floppy-type power connector to the front panel? I screwed up and didn't know about that once; it was funny later on :p
Yes, everythign is plugged in correctly. I'm trying right now to update the BIOS but I hate that Asus Update Utility it never seems to find a site it can use.
Ok, I have a total of 2 gig of ram installed in my rig two 512 sticks and one 1gig stick.
And the computer is only seeing 512.
What is going on? This is really starting to piss me off.
A few days ago it saw 2 gigs and now it's seeing 512? What the hell?
Well, I think it's officially shot. I moved the memory around. Rebooted the computer the fucking screen doesn't even come on.
I've had nothing but problems with this god damn motherboard since I installed it. I'm going to get in touch with Newegg tomorrow I'm going to send the motherboard, and video card back and I'm going to go back to an A8V Deluxe and a 6800GT.
I'm not sure how running two 512mb sticks and one 1gb stick will work with dual channel if possible even with this board would have to look.
The asus bios update from windows has problems with the audigy drivers specifically one of the programs that would not work correctly for me and yes I have the same problems with it connecting if I try to use it. You have all asus programs uninstalled from windows? The only program I use is asus probe 2 that's it. The others just caused me headaches or didn't work well or not at all.
Your memory both 512mb sticks are the same I assume and 1gb stick same manufacturer? Corsair? What about the specific settings for the memory you can check the actual corsair timings on their website and adjust accordingly if you ever get it stable.
One more thing try uninstalling your audigy one more time drivers and all from windows then make sure the card is seated at the bottom most PCI slot then reinstall. See if that helps if not you try without the card entirely and it's accessories?
Worst case here is what I personally would do prior to losing all hope. I would go over the Asus forums when I had some time looking into some things issues that I have in common and looking at the answers. Start froim scratch! Remove everything all video pci cards ram cpu. If this is unacceptable try this remove your pci cards and video cards. Next remove your ram all of it. Now install your video card back in then the 1gb stick of ram in a dual channel ram slot your manual will have labeled for you. Leave the 512mb sticks out for now. Only one hard drive the boot drive (windows). Make sure you ahve the boot drive on the Nvidia controller (sata) or the primary (IDE) I don't recall you stating what you had here. Don't connect a floppy if you have one leave it out for now. Connect your optical drive. Try it out and see what happens. If you are using the Sata ports make sure it's on the 1st connector not the 2nd 3rd or 4th. If it posts normally go into windows check your bios revision even with the updater if need be maybe update to 1009 if you haven't done that already like you said. Make sure to download/burn all updated drivers 6.70 nvidia chipset forceware for vid realtek sound (in case) your audigy drivers everything as newer chipset drivers will not work with older bios revisions keep this in mind.
Don't use the Asus motherboard CD ever at all costs I am serious you will have issues I had to reinstall XP 3 times before I was satisfied :).
Your best bet is to reinstall windows once it seems to restart and boot normally don't install any asus utilities remember that probe2 and the bios updater (sketchy sometimes) are ok in my experience everything else is garbage. Disable cool n quiet do not use this. Make sure the nvidia raid controller is disabled in the bios if your not using it. If you aren't using the silicon image 3114 sata ports disable it in the bios it's unecessary you can also disable the marvel yukon controller it's your second nic port you don't need it it eats resources if you use it then use it otherwise disable it :). This is all in your bios it has a vast amount of options.
DO not install nvidia firewall or active armor in the rare instances firewall can work fine however with offloading turned off most people don't need this anyways and can cause data corruption.
I can't really think of anything else at the moment probably some smaller things but regardless if this doesn't work for you you may want to look closer at your ram or the board and possible heat problem as well if that alarm is still coming up. You can diable all that in the bios as well.
Remove all your memory and check it one stick at a time it's sounds like your memory now.
Did that, got it to finally boot but it's still only seeing 1 gig now.
I dunno what the hell is wrong with this frickin' thing. I never had this much trouble with my Asus A8V Deluxe, I installed that thing and it booted right up with absolutely no problems. This SLi board has been a nightmare since I bought it back in November of 2005.
How do I get it to see the other gig? I've got the two 512 sticks in the black DIMM slots and that's the ones it's seeing now. The 1 gig stick is in the blue DIMM slot on the far left closest to the proc.
I just ordered two more 1 gig sticks. Maybe if I run 3 1 gig sticks it'll see it? I know there is something I have to enable in the BIOS to see the other DIMM slots but I dunno what, and furthermore, I'm afraid to even enable anything anymore on this thing cause it's so damn unstable. And I'm not even running it in SLi since I've only got one 7800. I can't wait to see what kind of problems I have when I finally do get a second card.
I didnt know anyone even used Standby. Sorry to hear about the problems. I will never use some of those things that microsoft puts in there. Hybernation, standby, recovery...
I hope everything gets fixed.
I use them once in a while. I've never had the computer go retarded after using them though...well that is not until I started messing around with SLi boards.
I got it up and running again, albeit only with 1 gig of ram. I'm almost afraid to touch it now. I've since shut it down and I've pretty much walked away from it for a bit. I think I'm gonna go get some breakfast and then think about playing a game.
