Ok, this is probably a stupid question...
but let's say I were to install Vista on a new Raptor I would buy. Could I leave my harddrive with XP (and all my mp3's) hooked and still be able to retrieve my mp3's from said harddrive while in Vista? That way I could transfer the mp3's to the new hard drive, wipe the old one and put the mp3's back.
(if this is retarded please dont throw heavy things at me)
*throws heavy things*
Yes, you can transfer everything back, should be no problem. You can even install vista on the same drive and windows will create a directory for all your old OS files called windows.old... where you can access all the old files and transfer them over.
