Ok, this is _REALLY_ weird.. help?
ppandemic
Ok. I am 100% mind boggled.
http://hardforum.com/showpost.php?p=1029107555&postcount=10
^ ^ better explination.
My friend has been having problems with his 9800XT and artifacting. So he came over to my house and I decided to find out what was wrong. So I put my x700pro into his computer. I then found out that my card acted weird on his comp. I put the x700pro back into my computer and found out that it was still messed up. The only thing that I could think of was that his motherboard had messed up his card along with mine. Now I decided to let him use a spare motherboard I had laying around. Now when I put the x700pro on the new motherboard it runs fine, but still not on my comp. The 9800XT is just not working on anything. And we went out and bought a x1300pro which runs on mine fine.
Any ideas?
wow..
we just tried that today. it seems to be screwing up every AGP card that is put into it. But i am not worried about that anymore. I am trying to figure out why the x700pro wont work in my comp but it will in his, yet the x1300pro will work in mine.
Motherboards don’t always seam to detect video card changes. When I see something like this happening I let the system try to boot without a video card, then shut it down and then put in the new video card. Give it a try if you haven’t already
agp cards seem to have a seating problem in my experience, take out the card and reinsert it and see if it works
try that like 4 times
when the loading screen of windows comes up, the loading bar doesnt look right. it is a few diferent colors and alot of small boxes move around with the animation. then when it gets into windows the entire screen goes green and yellow referee shirt.
and on my friend's comp it works fine.
yet the x1300pro works fine on mine.... >__<
I am still trying to get the weird part straight. Your 700 worked fine untill you used it on your friends computer? Then it was messed up on your computer? But then you tried it on a third motherboard and it worked fine again? Whos PSU did you plug the third mobo in with? After noticing that the 700 worked fine on the third mobo, did you try it on your original computer again? The 1300.... it does not work in your computer right? What about the third mobo?
yes.
correct
my friend's same one that he used with his original motherboard
of course, and it didnt work... this is the weird thing.
the 1300 does work on mine and on his (the third.)
Are you uninstalling drivers/using driver cleaner between all of these swaps?
wow, I really have no idea what could possibly be wrong, keep this thread active as long as you can, maybe someone will know...
edit: except overheating, that is all I can come up with. Are you two working on the computers in the same room? Can you lower the temp in that room, or both rooms if seperate?
Could you please post your power supply brand/model (and ratings if possible) as well as what all 3 motherboards are running, and what processor you're running in each one? Thanks.
