Ok, this has got me stumped!!!! (WARNING: long read)
jhzero1984
Hey All,
Here's the story. I Played BF1942 a lot a while back, to be specific a little while when patch 1.6 was out, but then unistalled so it wouldnt be a distraction during my studies. After some time I decided to reinstall it and then the problems began. After I had finished installing the game and the 1.6 patch, I would try to play the game but everytime it would crash at startup back to desktop or ,once in a while, it would start but once I tried to start a game (both multiplayer and singleplayer) it would crash back to the desktop and was unable to get it to work. So, after several unistall/install tries (even cleaning out the reg of the BF1942 files, REFORMATING the whole damn computer, and even, thinking it was a CATALYST version problem, installing an older CAT version)and looking for help on the internet (I was amazed to find others with the same problem and most could not fix it) I finally gave up sometime in April/early May. (NOTE: during this entire time I was able to play Medal of Honor Allied assualt, spearhead and Breakthrough and Sim City 4, and only having a few problems with SimCity that were easily resolved) Ok, so last week I decided to dig out an old favorite game of mine, Age of Empires 2, and install it to play. Well, when I tried to start the game, it would crash at startup, and every so often give me a message saying something was wrong with directdraw and the video card. This led me to test DirectDraw under Direct X diagnostics. After several passed tests of directdraw I knew it wasnt that. I decided then to run the Direct3d test, but every time I started the test, it would flicker a black screen then back to the DXDIAG screen saying that the test was cancelled because I pressed a key, which I did not do. So, I came to the conclusion that the problem was the vid card or DirectX. I decided to reformat again and do a clean install of everything. Once I got the computer up and running, with all drivers for Vid Card, Sound card etc. up to date and all general programs running (i.e. Word, Earthlink, Antivirus etc.) I installed Age of Empires 2 and tested it. This time it worked fine, even played a couple games. Once I felt Age of Empires 2 was fine, I ran the DirectX tests again. This time the Direct3d test worked fine. I then installed Medal of Honor and had no problems. But then after a day or two I thought it would be fun and see if BF1942 would work. Installed it, this time not installing the patch since some people thought this might be causing the game to crash at startup, and tried to get the game to work, but it went back to crashing like before. So, after two attempts I gave up and decided to go and play Age of Empires 2 but when I tried to start the game it crashed like it had done before. SO again I go to my trusty DirectX Direct3d test but it wont work again. I decide to do another reformat and installed the drivers and general software like before. I ran a Direct3d test once to see if it worked and it did fine. Then, after making a system restore point so I didnt have to reformat again, I started installing the games but started with BF1942 first. once I had the game installed with no patches, I ran the game and it worked!!!! then I tried the 1.6 patch and the game still worked fine. Also, ran a direct3d test and it worked fine. So, I made another restore point, then tried installing Age of Empires 2. Tried to start the game once it was installed and the game crashed as before. then tried BF1942 and it crashed. then tried direct3d test and it didnt work. This time I resorted to the restore point after BF1942 was installed. ran the game and direct3d with no problems, but then tried to install Age of Empires 2 and had a repeat of the crashes to desktop. (NOTE: I have not tried installing Medal of Honor in the last attempt since I havent had problems with the game before, but will after this post since I want to test a theory that BF1942 is the problem). Right now I am back to the restore point where BF1942 is installed but not Age of Empires 2 and having no problems with either BF or direct3d tests. SO, I have come to a few ideas on to what the problem is:
1. Age of Empires 2 and BF1942(and patch 1.6?) alter the same registry key or integral windows file so that it causes the problem, So it is impossible to install both games at the same time.
2. DirectX or the Catalyst drivers are corrupted by the combination of games(and patch 1.6?) and thus why I have the problem with direct3d tests and the games.
3. (this is the one Im going to test with Hedal of Honor install and possibly Call of Duty and Sim City 4) BF1942 (and patch 1.6?) and any other game installed causes a registry key, integral window file, direct X and/or Catalyst driver corruption that causes the above problems.
4. Or something is wrong with other software (antivirus which is Trend Micro internet security), hardware, or general setup (nothing is overclocked by the way) and the combination of games causes all hell to break loose.
But before I blow up my computer I want your opinions/theories/ideas on what else I should to try so I can get this resolved.Or is someone else having this problem or similar problem (ie. BF1942 crashes on them) PLEASE HELP!!!!!!!!!!!!!!
Sincerely,
Zero
p.s. Config should be in sig if you were wondering with everything up to date (drivers, windows update completed, virus software current) just in case you need the extra info.
Also, if this is in the wrong forum, feel free to move it moderators.
you couldn't be further from the truth... actually what you are experiencing is a well known problem to me...your refresh rate for your monitor needs to be changed and locked. go into monitor properties and make sure you turn up the refresh rate to something higher than 60hz, and then enable v-sync so it wont deviate from this. also there is a windows update that addresses this issue. if that doesn't work run dxdiag in the run box and go to the last menu...there is a "force refresh rate" option there as well.
Actually it was locked at 75hz when this all started. This is what the few successful people had done and told me to do when trying to resolve the BF problem the first time back in April. But, i just tried it again, this time through directX, but once I tried to start Age of Empires 2 (just reinstalled it again) I got the crash and got the message "could not initialize graphics system. Make sure that your video card and driver are compatible with directDraw". And, BF1942 also crashed after I did both the install and the refresh rate thing, even though it worked before i tried the previous. Thanks for the idea though, since I had not tried that with both BF and Age of Empires.
sincerely,
Zero
Im gonna copy and paste this to the vid card forum also since im getting the feeling its vid card related.
