Ok second try on a system and it still has problems.
This machine is just making me really flustered. I have the following parts:
http://www.newegg.com/product/product.asp?item=N82E16819115005 - CPU INTEL|C2D E6300 1.86G 775 2M R - Retail
http://www.newegg.com/product/product.asp?item=N82E16817189005 - PSU XCLIO|GOODPOWER 500W RT - Retail
http://www.newegg.com/product/product.asp?item=N82E16813131142 - MB ASUS P5N-E SLI NF650I SLI 775 - Retail
http://www.newegg.com/product/product.asp?item=N82E16814150202 - VGA XFX PVT71PUDP3 7900GS 256MB R - Retail
http://www.newegg.com/product/product.asp?item=N82E16820144028 - MEM 1Gx2|GEIL DII800 GX22GB6400UDC - Retail
http://www.newegg.com/product/product.asp?item=N82E16811119110 - CASE CM|RC-534-KWN1-GP BK RT - Retail
I plug in the power, all the lights on the motherboard light up. I press the power button and it lights up, goes to turn on and shuts down within a second or two. Any ideas?
make sure the HSF is properly installed. Also make sure all your cable connections are properly connected, mainly the 12V P4 connector. Did you try everything on a barebone setup? barebone setup: mobo on top of a cardboard box with just the cpu/hsf, one stick of ram, vidcard, and psu plugged in.
No I didn't. I've double -checked the HSF, got the cpu plug in and the huge 24 pin power connecter connected to the mainboard.
The HSF "snaps" in, just like it should. The thermal compound they put on is light, but it is sufficiently covering both the HSF and processor. I have checked the 24-pin connector so many times.. :(
I have the mainboard on struts. So it is not on the case, thus it isnt shorting.
Ok, update.
I figured out why it was doing that, I forgot the 12V :|
But now when I hit BIOS, it functions then shuts down after 15 seconds or so.
I always overlook the easy solutions first and go straight for the most difficult, time consuming stuff. Try reseating the memory and see if that helps.
Reset? As in reposition?
Update: It lasted longer, but still shut down after it started loading setup files for Windows XP.
Reseat, as in take it out fully, and put it back in firmly. Believe it or not this can help with wierd problems. Now it crashes when loading Windows? You are doing a fresh install, correct?
Do you get an error message? what are you idle temps like when you first boot?
