Boots fine. Windows splash shows up...then when it gets ready to go into actual Win I get a bsod, I have done nothing to it. I swapped out mem and vid card...still the same thing. Think I just need a new install?
If swapping HDDs seems to have fixed the problem, and you wish to use the old one anyway by reformatting and reinstalling... before going through all that trouble, I would run the HDD manufacturer utilities on the drive first to make sure that drive isn't toast.
Dude. Power the computer up and get into safe mode w/ the f8 key. If you can get into windows in safe mode then you have a bad driver.. I suggest removing video, sound, lan, drivers etc.. After removing the device drivers try to reboot and see if it doesn't boot back up just fine.. if it doesn't, it sounds like you'll need to reformat. If it does then just install your lan drivers from the disk and download the latest drivers for all your hardware..
The only time I've seen a computer boot w/ bsod are when something is OVERHEATING, power supply is fubr or if the user has swapped motherboards around. The new chipset will freak windows the f' out. That would require a reformat as well.
