no_control
- Jul 6, 2006
Ok I just bought this system for $500 What do i do with it? I've never water cooled before.
Asus A8N32-SLi Deluxe mobo AI Lifestyle Gaming Edition.
AMD Opteron 170 This processor was tested Prime95 Stable at 2.9GHz on AIR.
Corsair's XMS Series TWINX2048-4000PT.
Enermax Liberty 620Watts
X-Fi sound card.
He also threw in all of these H20 tidbits. I have no idea if they are considered good/bad/ugly I have no clue if it's compatible with the Hardware above.
(2) Swiftech Watercooling Blocks (MCW55) for the GPU and one Storm Waterblock for the CPU in addition a Swiftech Drive Bay Pump and Resevoir Kit. A Koolance PC3-426BK Liquid Cooled Case. This pc case is basically a Lian Li PC60 Aluminum PC case modified to accomodate a top mounted Koolance Water Cooling Unit.
I'd like to upgrade my current air rig with some of the above parts but I'm looking for a little guidence from experianced WC guys. What should I replace, use and get rid of?
Current rig:
Lian Li PC-60 slightly modded for air cooling
AMD X2 3800+ @ 2.55
2x 1gb A-data vitesta ram
DFI Ultra-D
Hiper 520w PSU
eVGA 7800GTX KO
X-Fi sound card.
XP-120 HSF
Thanks for the input.
X-Fi sound card.
Current rig:
AMD X2 3800+ @ 2.55
DFI Ultra-D
Hiper 520w PSU
eVGA 7800GTX KO
X-Fi sound card.
XP-120 HSF
