enlightenedby42
- Jan 19, 2005
I am not having any luck overclocking my i7 920, and I think maybe I'm just missing something in the settings. First thing's first, here's the setup:
CPU/HSF: i7 920 (c0) w/ TRUE Black and Noctua 120mm 1200rpm fan
MOBO: Asus Rampage II Extreme
VGA: EVGA GTX 275
RAM: 6gb Corsair Dominator 1600
PSU: Corsair HX1000
HDD: Boot Drive: X-25m SSD, Games and storage: WD Black 1TB
OS: Windows 7 x64 RC1 (build 7700)
My results have just been odd. I turn SpeedStep off, of course, and can go to 3.2 on stock voltages with hyperthreading enabled. This is stable in OCCT and 8 instances of cpu stress Orthos.
For some reason, I am hitting a total wall at 3.2 with hyperthreading enabled, and it takes .1-.2 volts just to eek another 1-200 MHz out of it. If I disable it, I can get up to around 3.5-3.6 on 1.4-ish volts and keep it fairly stable.
Temps break into the lower 70's at 1.4, but just barely cross 60 under load at stock. Not GREAT, but seems to be about expected for an overclocked i7 from what I have read. The errors I'm getting on CPU stress tests with HT enabled are basically ALWAYS bsod's.
The only other setting I have messed with is DRAM Bus voltage which I locked down just shy of 1.6. I'm almost certain that RAM isn't the issue, as it will handle 8 instances of blend or RAM stress tests in Prime without any issues at all.
I'm fully aware that overclocking is a gamble and sometimes you don't get lucky, but from what I have read and some of the comments Kyle and Dan have made about their experiences across several chips, I get the distinct impression that maybe I'm missing something here. It seems like my chip is hitting the wall of diminishing returns with voltage increases REALLY fast for an i7.
Is there perhaps another small voltage bump on an obscure component or another setting somewhere that is throwing me off that may be worth trying? Any suggestions in general?
I'm a bit stumped at this point.
VGA: EVGA GTX 275
PSU: Corsair HX1000
