ok, its freezing
quietRiot
ok, ive had my computer running at 200x10 just to keep it cool, and if had it running for a couple months like this.
so i bump it back up to 200x11, but keep all voltages the same, and now my computer freezes a lot, sometimes before i even get into windows.
ram?? psu?? help......
sounds like you might need to bump up the cpu voltage. we need more infomation though like your other hardware, voltages, temps, cooling information.
good temps, 40C load slk-800a
ram at 2.7v
vcore 1.775v then i upped it to 1.825, so far no probs, but its only been up 15 minutes
ill see how long it lasts
drivers arent causing prob, but since the prob started i updated to the new cats
also, if my temps are good, is it bad to up the voltage to say 1.9-1.925-1.95 as long as the temps stay good?
or do i risk probs with psu, etc
i have aan allied 400w psu that isnt great, but so far its been fine
