Ok I'm really confused?
Gofaster
Its time for a new pc and with Conroes great performance it looks as if I will build a Intel this time. But I have searched,download a huge excel file and read till my eyes are sore. Still confused.
Heres what i want:
Raid
SLI- I will be using a 7950 at first till they get drivers for quad sli
Gigabit ethernet
DDR2 800?
I really like Nvidia Raid and Firewall Software but thats not a deal breaker
So what board do I need? Looking for a fast system that will be used for photos,encoding video, and playing a few games. I really can say it probably wont be overclocked? Can you help a former AMD guy out?
Gofaster said:
Raid
Gigabit ethernet
DDR2 800?
Since you posted this in the mobo forum, I assume you're looking for a board....
Raid - They all have that in one form or another. SATA raid is pretty much a standard feature on all boards
Gigabit Ethernet - Some have it, some don't....what do you need it for? If you don't have some network with gigabit switches then it's useless. Internet won't be faster with it anyhow.
DDR2 800 - All of the newer i965 board or i975X boards support it
SLI - Forget it with conroes at this point. Crossfire yeah, SLI no....unless you want a nVidia chipset board and no overclocking. Because nVidia+intel+conroe = no overclock right now
Soooo...either wait for better SLI support or get a non-SLI board with the features you want. BTW what the heck do you like about the nVidia firewall?!?!?!?!?
I usually run my stuff in standard mode, no overclocking. I need it work everyday,run cool and be quiet.
intel 975bx board for stable, non overclocking.
asus p5wdh - stable, quiet, millions of features, 3 sata controllers, xfire, sli (not official yet, but it still works), built in wifi/wap, etc, etc.etc. and right now is going for not much more than the intel. and if you decide to oc later on, its one of the top 1 overclocking 975 board for 4mb l2 conroe for less than $300. the other 2 good overclocking 975 boards are a good deal over $300.
http://www.newegg.com/Product/Product.asp?Item=N82E16813121016
http://www.newegg.com/Product/Product.asp?Item=N82E16813131025
both can be found cheaper if you look around. the features alone make the asus a much better deal.
