Oil Immersion PC
Status
Not open for further replies.
Langer
Since the PC was born, we’ve been fighting heat. Conventional PC’s use combination of fan/heat sink, chassis fans and ducts to try to keep the machine from turning into the oven. But as the heat continued to climb, enthusiasts turned to liquid cooling the CPU and GPUs. Others have used a combination of liquid cooling and thermal electric coolers to help move temperatures lower.
Both of these methods face one problem though. Conventional fan/heat sinks can’t move the thermals fast enough and create too much noise and liquid cooling key hot components doesn’t do enough to help the surrounding components. So what if you took all of the hot components, dunked them in a non-conductive oil and sold it?
LINK
I had an idea about doing that. Where did you find those picts?
Link please i want to read article
Status
