Oh What Now?
gkg101
Win xp sp2 home
Opteron 185 dual core
Corsair HX620w
Asus A8N E (rev 1.2) >>>Asus A8N SLI SE (rev 1.2)
evga 8800 gts >>2 evga 8800 gts sli
2 gigs Corsair RAM 400ddr
Soundblaster audigy SE
Trial and tribulation events concerning system config changes listed above can be searched for gkg101 but don't bore yourselves. Suffice to say I'm dumb, wasted testing opportunities when I had the parts on hand, and made poor Asus RMA two motherboards when the problem was Opteron 185.
Anyway, awaiting return of RMA'd Opteron 185 which is on its way to AMD for inspection and hopeful replacement. My new motherboard is working fine i think.
Last night I decided not to wait for Opty 185 and would try to boot into my previous Windows installation using the my old processor, a single core 4000, and just 1 video card. Windows activation process has me temp stymied. I must call them back with product number etched on the installation CD because I lost or misplaced the windows product key. Cruel microsoft. I shouldn't have needed it imo. [EDIT, a default code appeared on the activation screen probably garnished off my previous install but the code didn't work :( Why present a code at all?] But probably for the best which lead me to this: In safemode I believe must reset ntune (arrived at under auto) tweak to default before Windows loads. Can I delete this 'best system' file in the ntune directory? I already disabled on board sound (got a soundblaster) so I think I'll be good to go after I delete that 'best system' file, and Microsoft returns my Windows (which I paid for). What I mean is there anything else to consider? Thanks in advance.
Since no one is replying, I'm guessing that I'm good to go. Tonight, after I get back from work, I'll call MS (found original install cd) I'll boot to safemode beforehand, delete the relevant ntune file(s), and see what happens. If anyone has any advice in the mean time, that would be nice.
Just thought I'd let you know, I followed my advice with safemode: deleted 'best.rpe' from ntune directory and set rivatune back to default.
I had my product code all along attached to the top of my case where the ABS company had placed it. Dooh. Windows is running fine.
