Oh no! Something went wrong, and its urgent!
Ok, so im formatting the computer in my sig today, actually right now. It was having problems with the windows install left and right, so i needed a format before my stretch of tests next week. Well, i back everything up onto my 2nd hard drive, restart, and format my windows hard drive. It goes well, it starts installing windows, it asks for cd key, it installs... then it does its customary restart... well now it wont go past the boot screen! It stays stuck at "Abit Engineering, press TAB to show POST screen, DEL to enter SETUP"
When i try to press any of those, it doesnt do it. I restarted, it still didnt do anything... it just sits there... what do i do!!!
did you do the quick format within the windows installation? if so try using the standard format which takes a little longer.
Javelin, u didnt read what i said, normally i would try to reformat, but i CANT GET PAST THE OPENING BOOT SCREEN.... NOTHING works, not DEL, not TAB, nothing...
ok now theres MORE problems! I finally get into windows, and i activate windows... then i reboot and it DOESNT SHOW anything... monitor stays in power save mode, no boot screen, nothing! NOW what do i do?
1. Every time you reinstall it does the same thing?
2. Are you installing the OS on a RAID array?
Try to install a couple more times to give us more data to work with.
1. The first time i ever had problems, i had a problem where it wouldnt boot to windows without my xp cd in the cd drive, thats the reason i formatted in the first place
2. Its not a RAID array
3. I cant install it a couple more times, i cant get into my computer at all! The monitor stays in power save mode whenever i turn on the comp!
does the computer sound like it is continuing to boot even tho you cant see anything on the screen? or does it stop and make some beeping sounds?
how much dust you got on things? :D
clean out your computer, reset the cmos again
make a floppy with memtest on it, and run it ;)
memtest turned out to prove that my memory is ok (at least as of last week).... Im usually pretty good about keepin my case clean and good on maintenance... I dust at least once a month, i change fans every year, i test my hardware as much as i can...
Stargazer: Yes my computer sounds like its booting up, thats the wierd thing!
If you get the boot beep but no video, try changing video cards. If you have onboard video try using the onboard video card.
ok well I would check all my connections first which I bet you already have, then maybe try to switch out with another monitor that you know is good, and maybe try to switch out video cards too if possible.
Ah shoot i dont have any extra PCI-E cards laying around... This is my first rig with PCI-E :(
ill see if i have any, hopefully i do.... do you guys really think my x800xl is bad? If it does end up being the problem, what can i do from that point?
try reseating your video card and any other cards you have. may as well do all the cables and RAM as well. do the video card last.
just take em out and plug em back in.
the PCI, ram and other sockets are made as cheap as they can get away with to keep the prices down. they have hundreds of pins. sometimes when you are messing with stuff it can cause one of the connections to become intermittant or bad.
No, I don't think your video card is bad. It has something to do with your motherboard or power supply, most likely your motherboard. Keep playing with it, make sure you don't have any case grounding issues. Do some more testing on when it will not start up. Can you get it to start at all? Go barebones and work your way up.
Ok i cant find an extra video card (pci or pci-e) to try my computer with.. how do i proceed now? Im almost positive i dont have a grounding issue becuase i have been using this setup for almost 6 months now with no problems.. oh yea i also swapped hard drives, still u can hear it tryhing to boot up but no signal on the monitor
You're really going to need a video card to test with, otherwise you can't be sure it's not the video card (which signs seem to point to).
In cases like this, the first suspect is the PSU. Test it with a DMM while it's connected to a load or still installed in the system.
Keep in mind that an old PCI video card will work for this purpose. That's the reason I have an old POS S3 card in the garage.... :cool:
I did my first PCI-e mobo yesterday, and I can say that they are fussy about their power connections. Make very sure that the motherboard's CPU power is connected properly, as is the extra power connection for the video card. The MoBo I worked on had an 8-pin connecton for the CPU power, and wouldn't come out of reset until I used the 4-pin -> 8-pin adapter....even though the polarity for the connection was the same; it really wanted power on all eight pins (+12 and ground). Also, this MoBo had a drive connector for extra PCI-e power. Turns out that the card didn't have the extra power connector but the MoBo did. Sounds like your problem may be related to something like this.....
Good Luck - B.B.S.
Probably not enough power going to the components in the computer.
The new motherboards are REALLY picky about power supply brands.
I'm gonna bet it's the PSU, yeah it's not a bad PSU but 2 80gb drives, 1 120gb, 2 optical, and a high end video card could possibly be enough to stress it if it isn't a really good 400w. I mean I have a fairly good Enermax 510w, and if I add another HD the system is unstable, and that's just adding it to the system in my sig. Try unhooking an optical drive and whatever HDs you don't "need".
Yea currently I only have 1 dvd burner hooked up, only 2 hard drives hooked up, my graphics card, sound card, processor (obviously), power supply. Thats all thats in my computer thats running as of right now.
BBS: What do you mean by 4 connector --> 8 connector? My PSU is 24 pin... or is that not what your talking about? (sorry im tired, not thinking right :()
Also everyone, is a Fortron 400w PSU good? (its the blue one) http://www.newegg.com/Product/Product.asp?Item=N82E16817104935
Thats my PSU that i have right now
Normally i only have 2 hard drives hooked up at any one time, the 3rd is strictly for backing up files
The board I build yesterday had three power connectors and the system wouldn't boot without them all connected properly:
- The "Standard" 24 pin motherboard connector.
- Processor power. Typically a 4-pin connector, this was an 8-pin connector on the system I built yesterday. While the 4-pin connector would plug in just fine, the system wouldn't come out of reset until we used (and found) the 4 pin -> 8 pin adapter that came with the motherboard.
- "PCI-e Power" - typically used to provide additional power to thirsty video cards. Some systems use a six pin connector that sure looks like the above mentioned 4-pin connector (though +12 and ground are reversed... :eek: ) but the system we built had a standard 4-pin drive connector on the motherboard.
Hope this helps - B.B.S.
Ok i reseated EVERYTHINg, then i did what BBS did and used the 4 to 8 pin adapter, and it worked! Thanks EVERYONE for all the help, Hardforum truly is as great as its reputation :)
