Im in the process of building a new computer. I just wanted to know if everything was compatible before I hit the Submit order button
Here is what I will be using from my old computer
MegaRAID SCSI U320, PCI Express Raid Card, 128MB
http://www.lsi.com/storage_home/pro.../megaraid_scsi/megaraid_scsi_3202e/index.html
4 GB of CORSAIR ValueSelect 240-Pin DDR2 SDRAM DDR2 533 Memory
http://www.newegg.com/Product/Product.asp?Item=N82E16820145527
Thermaltake TR2 W0070RUC ATX 430W Power Supply
http://www.newegg.com/Product/Product.asp?Item=N82E16817153023
2 HP U320 74GB SCSI Hard Drives 15k RPM & (2) 80 to 68PIN SCA Adapters. I also have the appropriate scsi cables w/ terminators. I will be also using my current DVD drive
Here is what I will be purchasing this weekend:
eVGA 640-P2-N821-AR GeForce 8800GTS PCI Express x16 HDCP Video Card
http://www.newegg.com/Product/Product.asp?item=N82E16814130071
DFI INFINITY 975X Socket T (LGA 775) Intel 975X ATX Intel Motherboard
http://www.newegg.com/Product/Product.asp?item=N82E16813136168
Intel Core 2 Duo E6600
http://www.newegg.com/Product/Product.asp?item=N82E16819115003
LIAN LI PC-7B plus II Black Aluminum ATX Mid Tower Computer Case
http://www.newegg.com/Product/Product.asp?item=N82E16811112099
Everything should play together nicely, no? Im open to suggestions/modifications on how to improve this build (if needed)
What do you guys think?
