Oh Man!!!!
OH MAN!!!!!
allright i have the4 MSI K8N neo but i live updated the BIOS to the new 1.2 i think it is and did they fix the temp monitor or anything?
i have the cooler master hypo 6 heatpipe HSF with double in blowing LED fans.
my bios is saying that my temps are about 61c!!! did they still not fix that because when i reach in, the heatpipes arent even warm and there is no heat coming up from under the copper plate that actually contacts the socked and with the stock cooler that heat was there.
im kinda worried although i dunno what temps a64 CPU's should run at besides, the pc specs are in my sig.
the newcaslte core chips read out very high temps on that board. there was bios that fixed some peoples temps but not all. i belevie msi is still working on the issue.
awesome thanks for that cuz it is a newcastle too screw clawhammer i want the OC baby.
when i posted my temps at 60c i had it OC'ed to 225 FSB at 1.65 volts.
i since then went back to everything stock and my temps went down to about 45-47 according to MBM5.
think i can get it stable with the 225 FSB and have the voltage at stock?
