Feb 29, 2012 #1 A ag55 n00b Joined Jun 10, 2010 Messages 32 So my chip seems to be able to do 4.4ghz at 1.34v How can i go about setting offset voltage? Thanks
Feb 29, 2012 #2 E extide 2[H]4U Joined Dec 19, 2008 Messages 3,494 What do you mean by offset voltage? Offset usually means that you are setting the voltage based on an offset from the stock voltage (like +.025v, etc) Versus absolute where you dial in an exact voltage (like 1.350v)
Feb 29, 2012 #3 T tangoseal [H]F Junkie 2FA Joined Dec 18, 2010 Messages 9,787 You need to select offset. I use 0.30 positive offset for 1.38v at 4.5-4.7'ish.
