So am I. I need some guidelines to work within...mikeblas said:
- Still waiting for artwork decision
Still no response from the collective? That's frustrating -- it's part of what's been bothering me for the work on the code.AtomicMoose said:So am I. I need some guidelines to work within...
Sizes, colors, what do you want the images to present? Do you just want banners? I need input.
I am not going to just blindly design stuff and have it shot down. Too time consuming.
I am fully willing to work for this project within guidelines. But I don't have the time to spin my wheels.mikeblas said:Still no response from the collective? That's frustrating -- it's part of what's been bothering me for the work on the code.
The website is black-and-white right now, and I don't think it would be too hard to change it using the CSS that I've written.
The banners that went by were fine by me; we could put 'em at the top of each page. I thought we were headded for another bake off.
Then I guess you'll have to hold off until somoene gives you the guidelines you want. I've given you everything I know, and I'm in enough hot water with the decisions I'm already making for the code.AtomicMoose said:I am fully willing to work for this project within guidelines. But I don't have the time to spin my wheels.
How frequently do you think users will uninstall and reinstall Yurt, cleaning the registry inbetween? I think we'd leave the password in the registry on the machine so that a reinstall would not generate a new one.amenthes said:In regards to the machine password function, what would happen if someone uninstalls and reinstalls YURT? The site would already have a password logged for that machine id, if I understand correctly, so it would want that password to authenticate. However the program would think it was a new install, and try to create a new password to send to the site, not knowing the old one.
mikeblas said:How frequently do you think users will uninstall and reinstall Yurt, cleaning the registry inbetween? I think we'd leave the password in the registry on the machine so that a reinstall would not generate a new one.
Then I'd expect a new machine because there'd be a new FAH ID after FAH itself was reconfigured.OSUguy98 said:What about the case of a complete format/reinstall? some are known to do that reather frequently....
Of course it is possible, but I don't think it's a very good idea. As soon as someone figures out the algorithm by which the password is generated from the ID, they protection is rendered useless. This is security by obfuscation.amenthes said:Would it be possible to generate the "password" based on the existing machine id? Something that the user couldn't replicate too easily, but something that would stay consistant with the machine ID even if the registry data were lost.
amenthes said:As long as the password is left in the registry, then I imagine this wouldn't be much of a problem. I can still see it happening though.
Yep.amenthes said:So I guess the item to put in the manual would be, if you uninstall YURT and remove the registry keys, then you must also remove and reinstall F@H, thus getting a new machine ID. Correct?
blakex said:Regarding registry keys, I install everything on my computer through Total Uninstall, so when/if I do decide to uninstall something, it is completely uninstalled - registry keys, files, everything.
I know I'm in the minority, but it is a possibility that someone could uninstall YURT and take the registry key with them.
You've already read about the problems that can cause for you here. Hopefully, other users will read the manual before they decide to do that.blakex said:I know I'm in the minority, but it is a possibility that someone could uninstall YURT and take the registry key with them.
Awesome! I will be waiting patiently for the email on the upgrade. This will be a good test of the capabilities. Will this require a restart of the stats?mikeblas said:I've converted YURTMonitor.EXE to work as a service, fully. I also put it on a diet; it dropped to 143360 bytes from 230000-something bytes.
I'll get YURTInstaller.EXE fixed up some time this weekend, unless something funny happens.
I'm thinking not. But you'll find your current client gets an error every thing it tries to send since the passwords will be turned on. I think I can make that work without deleting all the machine records, but we'll see.ICE_9 said:Will this require a restart of the stats?
mikeblas said:And maybe you'll even reconsider the practice for the rest of your software. Software vendors test their install and uninstall programs by running them. They don't test them by running them using some random third-party utility.
The stats are already public. Check them out by starting at http://beta.blaszczak.com/ShowListOfMachines.asp .blakex said:Looking forward to getting this going - should be quite interesting to see the stats that come from it.
Huh? What help file?MN Scout said:I noticed in the help file that there is a spelling error on the service install section.
This is already fixed.MN Scout said:When I went to the website I noticed one error report, this was within minutes of me registering.
I don't understand what you mean by "click under the teams list on a team". But I think I fixed what you're asking about. Let me know if that wasn't it.MN Scout said:Then on the teams list, if you click under the teams list on a team and then click on the machine count, there is not a link to the user list at the top of the page.
Oh, I see. It'll be fixed in the next drop.MN Scout said:the manual
It would be neat, but I'm more interested in getting everything else working for now. Remember, I'm the only guy doing dev work here and I've written upwards of 15,000 lines of code in three different languages during my spare time in the last month or so.OSUguy98 said:One suggestion on installing YURT as a service... Can we make that a decision in the installer? it would just cut out an extra step for the user.... A simple "do you want this installed as a service" pick box or something would work.... then, to uninstall, just rerun the installer and uncheck the box....
YURTMonitor supports an install comand on its command line. The docs explain how to use it. I don't understand what you mean by "create a shortcut"; who creates a shortcut for what? When, and why?OSUguy98 said:edit---- Either that..... or use something similar to the flags that FAH uses.... just create a shortcut to YURTmonitor, and add "install" to the shortcut.... or does that work now?
Did you know that you can press CTRL+INS when a message box has focus? That copies the content of the message box to the clipboard as text. Then, you can paste it into a message and not have to worry about screwing around with an image.OSUguy98 said:edit #2---- I'm having some problems with "foldingbox1" (one of my PCs).... here's a pic of the error I'm getting.....
Notepad
The text in the Untitled file has changed.
Do you want to save the changes?
Yes No Cancel
Previous betas were using WinINET. This library isn't supported for use in a service. To make the application work as a service, I have no choice but to use something else.OSUguy98 said:Using WinXP Pro SP0 for "Foldingbox1", "Foldingbox2" and "B"...... my PC "A" is WinXP Pro SP2.....
What is VNC? I've never heard of it, so it's unlikely that I'll support it if it is something that's going to get in the way.OSUguy98 said:also... see edit #3 from my previous post
Sorry, but there's just no way I'll support that.OSUguy98 said:quick and dirty fix was just to copy that dll file to the system32 directory.... After I searched on my PC, I saw it was in there and in "WINDOWS\ServicePackFiles\i386", so I figured it was an SP1 thing...
SP1 (and, better yet, SP2) is free.OSUguy98 said:I know... but there's no way I'm paying $100 for each of these PCs to sit in the corner and fold... and I haven't taken the time to learn linux well enough to switch
mikeblas said:Did you know that you can press CTRL+INS when a message box has focus? That copies the content of the message box to the clipboard as text. Then, you can paste it into a message and not have to worry about screwing around with an image.
mikeblas said:What is VNC? I've never heard of it, so it's unlikely that I'll support it if it is something that's going to get in the way.
It would be kind of goofy. Some machines (most that aren't in a corporate environment; who runs a domain controller at home?) don't have a domain name. So giving the user the choice between registering "blah" and "blah" wouldn't make much sense.unhappy_mage said:First, in the "options" dialog for YURTInstaller, it'd be nice to have the FQDN and machine name for this machine displayed instead of examples. Would this be tricky to implement, or cause problems on some machines?
The problem is that we don't know where the user has put YURTMonitor.EXE, so we can't run it from YURTIntaller.EXE. While most/many users would put them in the same directory, there's no guarantee they they did. To guarantee it, we'd need to write an instalaltion application, and I'm really not into signing up for even more work right now. The same problem applies to a shortcut; we'd need to know what the target of the shortcut is.unhappy_mage said:Second, as OSUGuy mentioned, it'd be nice to have a method to install as a service without resorting to command line; for some users that's scary stuff. Even creating a .bat file with "yurtmonitor install/net start YURTMonitor" would do it.
Thank you for your kind words and encouragement.unhappy_mage said:and thanks for the new version! It's awesome!
Indeed, I'm working on it. I already know (and have acknowledged) that it is a problem; after all, I was the one who noticed and diagnosed it. I'll fix it as soon as I can.enhnaced08 said:I know your working on the problem but I figured I would throw this out as well
