I have not had time to reseach it but I would think the entire 24" display would be filled at 1080p. I have black bars on the top and the bottom. Like I said I have not had time to research this but it does not sound right to me. But when I pay an HD movie through my Xbox HD drive to my 1080i Sony TV I get bars on the top and bottom too. Soon I will get a chance to start checking into this.
While definitely a problem, I wouldn't recommend using VGA on an LCD monitor anyway, so it's not that big of a deal. Can the problem be fixed by reducing the red color setting?peTeMelster said:Red saturation on VGA (limited problem, seems to be limited to RepairTech when they switch out the mainboard)
That would definitely be a problem, but how widespread is it?peTeMelster said:Blank signal for a second problems on DVI. Seems to be a common problem that some users claim can be fixed by buying a better DVI cabled and not using the BenQ supplied one. However, at least two users are using an expensive DVI cable and still have the same problem. This seems like a huge problem to me.
That doesn't sound like a defect to me. It's probably cropping for overscan. People keep saying they want 1:1 mapping when they really want aspect scaling. The updated firmware provides both.peTeMelster said:The 1:1 fix doesn't seem to work perfectly as sometimes an input of 1920x1080 will result in black bars on all four sides, however, using "aspect" fixes this. Still, it doesn't make sense why 1:1 with 1920x1080 would cause black bars on all four sides.
It may take much longer than a week for the blank signal over DVI to start occuring.
Also, I would say while the VGA red tint and blank signal are major problems, I have beef with other problems as well:
-add this to the list: lopsided monitor
-PIP is crap
-not as good colors or wide viewing angle as S-IPS
Couldn't disagree with you more on this point, I use eizo monitors at work (photographic lab) and my FP241W is every bit as good with color reproduction and the difference in viewing angle is nil or very close to it, that it's impossible to perceive.
- No tilt with my screen
-My picture n picture works exactly as it says in the manual
-No discernable difference between D-Sub and DVI-D inputs
-Very low twinkling effect when watching movies (best in class)
-No Backlight bleed
-No input lag
Really this monitor is best 24" under $1500
-Other people seem to say otherwise, that S-IPS is better.
-There is a discernable difference between D-sub adn DVI-D (1. red saturation on VGA, 2. blurrier text on VGA).
-Maybe no tilt in your screen, but a few people have said they have tilt.
-Sure, PIP works like it says in the manual, but it doesn't work like the Gateway PIP. In other words, the BenQ PIP is limited in function to the point of being essentially useless (crap).
Ive heard many good reviews ona 37" westinghouse 1080p HD for $999 and honestly no bad reviews from anyone. "yet" I should add.
OMG look a tft is blacker then a CRT!!
Seriously, read this article about LCD technology learn something guys and keep the flaming low, its crazy. The monitor has perfect colour reproduction and blacks are black, greys are grey etc..
http://www.xbitlabs.com/articles/other/display/lcd-parameters.html
CRT monitors can’t have an absolutely black screen? How can anyone even say that? I'm looking at my 19" CRT besides the BenQ fp241w and it is way darker. I tend to watch my movies at night, in darkness. Not in daylight. Sorry but blacks are not black. It's a great monitor yes, but lets not think any lcd matches CRTs in dark scenes.
All this talk about resolution, response times etc is for nothing if they can't reproduce blacks. Especially for movies.
Hi Guys,
I received my replacement monitor a few days ago. No dead pixels or tilt and with 1.1 firmware.
I've just noticed that I have lighter patches on a black screen. The background light does not appear to be evenly spread. I can't remember if my old monitor had this.
Does anyone else have this and would you consider it a fault?
Thanks!
Err all over
I got patches of light in over 70% of the monitor. But it is particularly bright in the left areas.
I can't remember the other monitor having this.
Would you say it is a fault?
Hi jcbguk,
It was good to chat today, as one of the many things discussed, BenQ UK do monitor posts on this and other forums on a daily basis, have done for a few years. Where we can help and post replies we try to.... agreed not as often as we should. our office move (eventually after Buncefield explosion 14 months ago) it's been a little manic. I'm hoping you will see more from us in 2007.
emails coming into the UK offices are usually turned around in 3 hours where possible, sometimes not possible but we do try to maintain where possible.
so just to clear up a couple of questions you had:
FP241WZ. will be available from the end of February. We don't expect much delay here, buy UK for a swift warranty.
Silver/black: one reason this is the colour of choice for Europe is to work within TCO guidelines/recommendations for PC Monitors. If the frame surrounding the display seems too dark or too light, a problem with contrast is created which is extremely tiring for the eyes - TCO.
FP241VW. UK reviews will be out before end of Feb, Z and non-Z have already 7 UK Awards. it's the monitor I use personally and yes, I paid for it!
PerfectMotion - it's a personal thing, I've been promoting it since the summer and response varies. when you get it, try each level to see what suits. but remember to switch off for desktop apps!
Who's panel? AUO are part of the BenQ Group.
Brightness it's a 500cd/m2 screen that's flexible screen for work & home, have a play with the settings to suit your needs... half the fun of new toys right?
Anything more general we can try and help, our UK service centre really do try to offer the best possible service. Where we see post about specific problems we do forward on, to get a better understanding of customer issues.
Hope this helps, thanks for keeping the faith in BenQ, we're only 5 years old as a brand and one thing I can assure you is that we're passionate about our brand & products.
JB
BenQ UK Marketing Manager.
Really? Do you have a digital camera? You're going to need a pretty dark room to take the picture of your monitor to see the uneven backlight.
Well here you go guys. Here is my monitor replacement with the backlight bleed issue I was reffering to:
The image is grainy because of the low light levels and high ISO that I had to use. But this is more or less what it looks like.
I don't know about you but I think this is a major fault - for the second time! Only before it was a dead pixel and a wonky stand.
I made a previous post about photos which i have copied below. I hope it helps.
Jafro
Hi All,
After almost 2 weeks of waiting I finally recieved my monitor from NCIX and it is spectacular. No pictures that I have taken or anyone else on this site has taken do this monitor justice, the quality is just that good. I have just started playing with it, but I thought would put up a few pictures for you guys. I have been having problems with my 8800 gtx and its drivers though, and it is causing issues with 1:1 mapping in games via dvi. When I run my laptop through the vga input, the same game (Civ 4) will map perfectly 1:1. I will try to resolve the issue and post more pictures and a full review this weekend.
For now, enjoy the pictures, and I hope all of you have broadband!
The main files is about 65 megs and the 360 file is about 24 megs.
All were taken at the highest quality and least compression with and 8 megapixel camera.
All pictures have captions describing exactly what they are.
They are all zip files, sorry if it is an inconvenience to anyone.
For Main Files
Link = http://www.mediafire.com/?4zgwddmlzll
Another, but slower link - http://www.megaupload.com/?d=U31CDYPP
For 360 Files
http://www.mediafire.com/?3iyjtmdqjmd
Let me know if the links suddenly stop working, I tested it after upload and all of them worked.
Try the mediafire link first, it is faster.
I also chose to split up the 360 pics from the rest because I know some of you just want the 360 pics.
All 360 pics taken via componant.
I have taken pictures of the 360 at the resolution page in the dashboard.
480P,720P,1080i, and 1080P - a pic of each resolution at each mapping setting (Eg 1:1, aspect,full) so that it is easier to see the difference.
There are also some pics of Gears of War in there just for fun.
I also took some pics of Civ 4 via dvi at native rez.
And some non native rez pics from my laptops vga. EG(1024 X 768,1280X1024,1600X1200)
I also took some pics of the overall screen realestate of the monitor and I took some showing applications and how much more space you get to work. (Photoshop,Premier,Word,Powerp oint)
Finally, I took some pictures of my N64 hooked up via composite. The 1:1 worked beautifully.
Also, if anyone would like a RAW (CR2) copy of any photo, just pm me with an email address and i will send it to you.
Enjoy!
Just got my Benq FP241W from NCIX today. Just hooked it up and calibrated it with a Spyder2Express. Colors looks more natural now. Upgraded from a Dell 17 Inch LCD. Need to hook up the PS3 with HDMI and WII with component. Using a X1950 Pro AGP on a Dell Northwood 3.0 Ghz. Will try and post some pictures tonight.
