Office space all over again... UGH.
Weenis
I said WEENIS, not...
Not literally but. I wanted to ask people whats a good reliable printer that isn't a complete and total piece of shit. I have an HP desk jet 6480. Because it decided that it would only print one of the queued documents then just stop.. for no reason. I missed an appointment with a dean and had to call and say.. I can't come see the dean because my printer is being an asshole.
I've restarted it, restarted my machine, it just decided it would stop printing.. it's done this before.. almost every printer I've had (epson stylus photo printers and this printer) does this..
I'm fucking furious about this I'm about ready to throw it out my window (and i live on the third story).
Does anyone know if this is a bullshit windows problem or is it simply the printer drivers?
Perhaps cannon printers are better?
I'm at a loss
EDIT: It also likes to do this where when I delete the printing queue it says "deleting - printing" and never deletes it.
you might try stopping and restarting the spooler service to get it to print....sounds like something more in your setup than a printer problem if it has done this with more than one printer
Do you have the HP bloatware installed?
How big are the documents you are trying to print?
Have you tried a different USB port? (assuming u are using usb ports)
If it doesn't take multiple printer queues it could be a software/driver problem. Try reinstalling that first and if it doesn't take care of the problem try replacing the USB cable that is connected to the machine. If it further causes problems try doing a diagnostic check/manual reboot from the printer itself (some printers have this function like All-in-ones and bigger machines. I believe the OJ is an All in one?) which you can find on hp.com for further instructions. Other than that...printer quality has gone down over the years and depending on how long you've had it, I hope you bought an extended warranty because HP's warranty sucks. :D
Edit: if its more than one printer but they are both HP printers then something is going wrong with the drivers. If they are from different manufactures well...it sounds like a totally unrelated problem that is affecting your printer drivers.
I recommend Canon MP510 or really anything from the MP line. Gorgeous printers, really.
Thats Staples training right there folks. lol!
yeah its happened numerous times.. its a brand new cable because it was being used as wireless.. it just works sporadically, this is about the 3rd time I've installed it... thanks for the advice ill have to try running diagnostics.. and try hooking it up to the new pc i just built..
but yeah i use the HP drivers from the site.. canons looking awfully nice
Unless you need to print color images, I'd recommend a brother laser printer, or any brand laser for that matter. If all you need to print is documents, they're great. I have a brother hl-1440 and I'm still on the original toner cartridge after being here for 3 years. They're a little more upfront, but they last forever and just plain work.
Here's one to get you started, it doesn't look to bad: http://www.newegg.com/Product/Product.aspx?Item=N82E16828113165
I'm at a loss
Perhaps the print-spooler (microsoft) is going out to lunch if you are seeing this with multiple printers. Check MS for any updates/patches related to the spooler.
<rant>
</rant>
You forgot your rant tags! :eek:
I would try unplugging the printer, uninstalling the drivers, shut down, plugin printer, load drivers.
If that doesn't work I wouldn't bother trying anything else, missing a meeting with the Dean is serious &%$#. That and it'll probably do that @&#$ again.
