Hello, I know this is HardOCP and that the goal is to get the best possible performance and all, but I also know this community is really knowledgeable as well. I really need that expertise at this point. I'm hoping for some advice and insight on how to build a computer that's good for accounting and office business use. The last pre-made computer I got from HP had its GPU die on me within 2 years... on an office computer dedicated to just business. Ouch...
I'm hoping I can get a build that's durable and has enough oomph to a few years.
- Business accounting use
- $650 taxes included, hopefully in the $550 range if possible but don't want to be stubborn about if it's cutting corners I shouldn't be.
- I live in Canada, Ontario, Toronto.
- I'll need a Motherboard, CPU, Power Supply, Computer Case, RAM, Storage Drive, andWindows 7
- I'll be reusing a DVD Drive, Monitor, Keyboard, and Mouse.
6) Will you be overclocking?
- No.
- I have a hand me down 20 inch NEC LCD monitor.
- As soon as possible.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
A little bit of future proofing. I guess that's really just USB 3.0 in case 5 years down the line USB 3.0 devices has completely replaced USB 2.0 devices and my accountant needs something like that.
- No, I'll have to buy a Windows 7 64 bit OS.
On a side note. NCIX is offering the following for $592 CDN before taxes. Are the components here decent at all? Is it worth just buying as is? Is the power supply in that case decent? Thanks in advance, everyone!
AMD A10-7700K APU Quad Core Socket FM2+ Processor W/RADEON R7
ASUS A88XM-A mATX FM2+ DDR3-2133 1PCIE16 1PCIE1 1PCI 6XSATA USB3.0 HDMI Motherboard
Kingston HyperX Fury Memory Black 8GB 2X4GB DDR3-1600 CL10 Dual Channel Memory Kit
Seagate Barracuda 1TB 7200RPM 64MB SATA 6Gbps 3.5in Internal Hard Drive - OEM
Inwin BK623 mATX Tiny Tower Case Black 1X5.25 1X3.5 1X3.5INT Front USB Audio w/ 300W PSU
- No.
