The compatibility pack is to allow pre-2007 Offices to open Office 2007 documents, but Retardo is having the issue of opening Office 2003 files inside Office 2007, which should not pose an issue. I open 2003 files in Office 2007 all the time since I use different versions between work and home.
Office 2003 docs open just fine in Office 2007. I'm using Office 2007 at work, and the other 34 people are still using Office 2003. I can open their files, and they can open mine. I've never seen someone as biased as you, even to the point they will spread incorrect information just to enhance their own bias.Well to Microsofts great compatability \o/
Get OpenOffice, it will open that file perfectly. You can then either carry on with using OO (recomend) or re-save it and open in MS-office07
now you are starting to see what is sooo wrong with MS
OH dear you FAIL!i try to open a word/powerpoint document made in office 03 in office 07 and it wont open.
Some ppl just can't see the wood for the tree's
Instead of dragging this down to the usual flamefest you always seek, I'll stick to the topic. You dig your own holes well enough, no need for anyone to get sucked down into them as well.*snipped out the crap*
