Offical razer AC1 drivers are out Finally!
http://www.razersupport.com/index.php?_m=downloads&_a=viewdownload&downloaditemid=88&nav=0,9
These drivers are offical, look like there for vista 32,
Edit:The drivers works, the Razer panel is a new app in this one so its not design to work in 64bit vista, Only 32bit ver. I was able to get a look at it by using the old app in the new app spot. But the files for it is coded diffent.
So they had had to got it working right in vista, it just I dont have vista 32 so i cant tell you what they did or not.
No way I can get the Vista32 razer panel to work in vista64 the vista 32bit razer panel been coded to work it might work now. Like all of the settings working right and what not.
I just cant tell you unless I go and go back to my vista 32 from my vista 64.
If some one has get a chance could you take screen shots of the control panel in vista 32.
thanks.
