OEM CPUs?
Hey all. I'm looking to upgrade my current Intel 478 2.66 GHz with a 3.0+ Prescott. I was looking and the only thing that i can find cheap are OEM CPUs. Is it a bad idea to get an OEM CPU or am I worrying for nothing?
Also, I have an Intel 875 mobo. Could I possibly put in a Yonah-based chip?
On a CPU that old don't worry about OEM or not... more than likely the warranty is out anyway, maybe not though. The ONLY difference between OEM and Non is the warranty, well... and you get a HSF with the Boxed verison if you are buying new. Don't stress.
As for the Yonah... nope, won't work sorry. First off the mobile CPUs are s479, but beyond that they are not compatible with that chipset. You may be able to use a Dothan, depending on the board you have. IIRC Asus makes an adapter for their 875 boards.
SL9JP 2.33 GHz T2700 N/A 667 MHz 65 nm D0 2 MB 478 pin
SL8VN 2.16 GHz T2600 N/A 667 MHz 65 nm C0 2 MB 478 pin
SL8VT 2 GHz T2500 N/A 667 MHz 65 nm C0 2 MB 479 pin
SL8VP 2 GHz T2500 N/A 667 MHz 65 nm C0 2 MB 478 pin
SL8VQ 1.83 GHz T2400 N/A 667 MHz 65 nm C0 2 MB 478 pin
SL9DN 1.66 GHz T2300E N/A 667 MHz 65 nm C0 2 MB 479 pin
SL9DM 1.66 GHz T2300E N/A 667 MHz 65 nm C0 2 MB 478 pin
SL8VR 1.66 GHz T2300 N/A 667 MHz 65 nm C0 2 MB 478 pin
there are 478 processors, but it wont work with that chipset. they'd require 945 instead
Thanks all for the replys. I went ahead and got the 3.0 for $117. I'm really excited as it'll take my FSB from 533 to 800, double my L2 cache, and add HT, so I'm really looking forward to tomorrow.
