Hi, I have a setup at work with several offices around the world and I've set up VPN connections between them.
We have a central office in the UK, and so far I've setup connections to offices in boston and SanDiego. The UK office runs a PC running linux as the router since we're bonding ADSL lines (which all works fine) and I've used the webmin interface to create VPN connections (tunnels) to both other offices.
The other 2 offices both have fairly average VPN routers installed for web access, the tunnels terminate there. All the networks have different subnets so we can access devices across the tunnels using the real IP's, everything works from UK outbound, including connecting to the SBS servers in Boston and SanDiego, but while RDP into them servers I cannot ping anything on our local UK network, including my own PC.
Anyone know the likely cause of this? It appears that their end just doesnt know the route back to our network...
Thanks
Thanks
