System was assembled less than a month ago. I have a problem where both monitors would blink off and then back on like there was no signal momentarily. I don't think it is the monitors, because both are doing it at the same time.
The first time I noticed this while playing Starcraft II. It happened about 45 minutes into actual play time. It then kept doing it what appeared randomly. I turned on the hardware monitor and let it run on the other monitor. The video card temp hit a max of 48C and a 50% fan speed.
I updated to the latest nvidia video drivers (270.61). I have not had time to test in game, but I now notice the problem occasionally on the desktop.
Anyone seen this before or have any ideas?
System is:
CPU: i7 2600k with stock cooler
Motherboard: Asrock Extreme4
Memory: GSkill 1600 8GB
Graphics Card: MSI N460GTX Cyclone 768D5/OC
Hard Drive: Crucial C300 64GB + 2TB WD Green drives
Power Supply: Corsair TX650W
Case: Antec Three Hundred
OS: Win 7 64bit
Monitor: 2 x Acer S231HLbid 23"
System is:
OS: Win 7 64bit
