I might be overthinking this, but I wonder if maybe I used too much paste
Do these temps look normal for stock, I am concerned about the fluctuation at idle
I left my PC alone at stock speeds for an hour and these are the idles, the max looks odd I see it just jump from like 28 to 40 degrees and back in a second,
Should I take the heat sink off, clean and reinstall?
idle @stock
and this is at 100% CPU utilization after 6 minutes
I am happy with the temps at load so I am thinking this is okay, but looking for some other opinions
6700K @ stock with Noctua NH-U12S 2 fans
idle @stock
