Odd Stuck Pixel Column
-=JaySin=-
I was in Windows 7 Explorer when a purple vertical column appeared on my LCD screen. It is about a 2 pixel wide 1050 pixel tall (top to bottom of screen) neon purple line that appears over every application, even the LCD's "No Signal" screen, so it is not a video card problem.
The line disappear after a few minutes, but then reappeared 15 minutes later. It has has been over a day and it has not gone away.
I have tried stuck pixel programs such as Undead Pixel which simply rotates throughout a set of colors, but it has not helped.
The neon purple line is very noticeable on a black bacground but it is not very noticeable on a white background.
The screen is is a BenQ FP202W and it is not under warranty.
http://www.newegg.com/product/product.aspx?Item=N82E16824014105
Any solutions?
Hmmmm... sounds like its dying... if you can live with it great, but it seems that you may be looking for a replacement...
Dying? You mean its slowly breaking? Would a LCD exhibit a greater frequency of stuck pixels towards the end of its life cycle?
That's usually the trend. It will get worse over time. If I were you I would start looking for a replacement.
