I have six hard drives here.
Three WD6401AALS 640GB (I'll call raid Array1)
Three WD6400AAKS 640GB (I'll call raid Array2)
Now each of the three sets of drives are in their own raid 0 array (about 1.7TB each).
I ran some disk read/write tests and found something that seems odd.
Array1 had:
Data Read Speed: 319.3 MB/s
Data Write Speed: 318.3 MB/s
Array2 had:
Data Read Speed: 306.3 MB/s
Data Write Speed: 296.8 MB/s
So the result is that Array1 is faster then Array2.
However, Array1 is the OS (Vista X64) install drive.
So shouldn't Array1 be slower or are the "black" drives that much more faster then blue?
Also, does it matter what sata plugs are used in the motherboard?
For example, if motherboard has six sata ports, will the drives in 1-3 always have higher allocated bandwidth then drive 4-6?
I think I recall setting Array1 in ports 1-3 and Array2 in ports 4-6.
Array1 had:
Array2 had:
