Odd Problem
Elloquin
Hello,
I have a strange motherboard problem and I decided to come to this forum to ask for advice. There has always seemed to be alot of well informed people on this forum (I have browsed this site for a while just lurking so to speak). Onto the problem:
I have a gigabyte GA-PE667 Ultra 2 motherboard. I am trying to use it in a new computer. The problem occurs when the computer boots up. It posts just fine, reads cpu, ram, voltages, etc but after that it just stops at the hit del to enter setup notification. At first I thought it may be the keyboard but I have tried 3 different keyboards with no success. I also tried clearing the cmos via the battery method with no success. I also tried removing all peripherals save the video card and no success. I have seen one other post with this same problem but with a different motherboard but that thread didn't go anywhre. Any help would be greatly appreciated :)
Often people don't successfully reset their BIOS. Wait a full minute after taking the battery out and disconnecting the Power Supply form the mainboard. I know you probably already tried this but bear with me, I work in IT tech support so I have learned to make my help thorough. (Lots of sad tech idiot stories) Also try using the jumper on the motherboard to clear the BIOS. Your manual will tell you how to do this.
Next try replacing the keyboard. I KNOW you have tried this, but try a PS/2 or USB (whichever you haven't tired).
If none of this works then your problem is narrowed down to one of 3 parts. Mobo, CPU, or RAM. I am going to bet that the RAM would be the problem because in my experiences at work, RAM is always the most failing component of the basic subsystem on a computer. Switch the ram with some other RAM that you know is good. Let me know how this works out. If all this fails, just RMA your motherboard like I am in the process of doing as I type...
