I have a Celeron 900 with 384 MB of RAM. It's using an MSI motherboard (can't remember the model number). When I got this computer about 6 months ago from my sister it worked fine at her home. I took it home and moved all the hardware into my spare case. When I turned it on, it would POST just fine, but when it tried to boot the OS it would access the HD for a few seconds then reboot, over and over. If I tried to install an OS on it, it would make it partway then reboot. No matter what I did, it would not boot. After letting it sit for about a month, I messed around with it a bit more and it suddenly started working just fine, for no apparent reason. I used it that way for a few months, even installed Linux on a slave drive, and it all worked just fine.
Fast forward to today. I am moving this hardware to the living room for use as an HTPC. I removed the hardware from the case it was in and put it in a different case, and the same problem started again! No matter what I do, it won't boot. I have tried this:
2 power supplies
2 hard drives with known working OS installations
2 IDE cables
Primary and secondary IDE ports on MB
Moved hardware back into original case
Reseated CPU with new thermal paste
Reseated all hardware
Removed all PCI cards, leaving only AGP video card installed
Unplugged all but keyboard and monitor
Checked every BIOS setting 10 times over
Here's the messed up part - I have Knoppix on a CD, and I booted off that and it ran just fine, no problems whatsoever. I am at a loss here. Since I could boot and use Knoppix off the CD, the IDE port and cable must be fine. When I put any working HD on either IDE port it craps out. Since the problem started both times when I physically moved the hardware from one case to another there must be something physically within the case setup causing this. Does anyone have any ideas? I've built many computers over the years and have never had problems like this before. I'd be extremely grateful for any advice.
2 power supplies
2 IDE cables
