I have been trying to figure out why the hell my computer cant play any game I want to on full settings, such as Colin McRae's DiRT, sometimes Oblivion lags as well. I dont get insane FPS like everyone else clames to get. usualy get between 25-90. Here is my Machine
MSI 8800GTS 640MB
AMD X2 4200+ @ 2.5MHZ (dual core)
2 Gb All Components ram @ 667Mhz
Maxtor 160GB @ 7200RPM (im pretty sure thats the speed)
MSI K9N Platinum Motherboard
Sound Blaster Audigy SE sound card
620Watt Corsair PSU
So I did some troubleshooting, I though it was my ram. So I removed the second stick of ram, booted up the PC and ran Colin McRae's DiRT and played a track that I knew lagged. I still got around the same FPS, which is 18-30 (horrible! and the settings arent maxed) and the game ran smoothly. So I thought it was the stick of ram right?
So i put that stick of ram that I had taken out, back in and took the other piece of ram out. So now the supposivly bad stick is in place. And again the game ran the same as it just had before, it ran smoother than it did with 2 sticks of ram in and it got the same FPS.
I know it sounds like a motherboard issue, but I shouldnt be able to run games smoothly on 1gb of ram should I? Im not sayin it runs perfect, but it does seem to run better without a second stick of ram in, reguardless of which stick it is.
Is there some way to test my Motherboards ram slots? I ran memtest a few months ago and everything came up clean.
Thanks in advance.
MSI 8800GTS 640MB
620Watt Corsair PSU
Thanks in advance.
