Odd Points?
It is interesting no one has commented on this. I have the exact opposite situation on a couple of GPU WUs. On a couple of 768 WUs, I'm getting half of what I should be. I did a restart of the box and the issue seems to have corrected themselves.
Sounds awfully high for one core, but if you've updated the WU database and fahspy (I love fahspy btw) is calculating correctly, then maybe??? I'd recheck it manually.
I did update f@Hspy just to make sure and it still showed 11k. The proof is in the 1min times. Not sure what caused it, but it has since dropped back to normal.
