Odd PCIexpress problem
Just wondering, has anyone had a PCIexpress slot just up and stop working on them? I'd just like to know that at least im not alone in this scenario.
I recently came back to my computer frozen, i tried a reboot and all i got was a blue screen with some error about nv4_disp.dll or something akin to that which sent a signal to me that there was something up with my Nvidia display drivers, so i safe mode it uninstall install latest, same issue, roll back a few revisions, same issue. So im like ok, maybee my vid card has died again *on 3rd RMA* i plug in a backup vid card, everything works fine
then later on i get the idea that its about time for a reformat just to make sure its not the vid card. I format and reinstall windows with the original vid card put back in. I still have the same issue, so im like ok im good for a RMA then i've tried all I can *no other boxes to try it in* so i install the backup vid card, BOOM its having hte same issues <.< i swap them back and forth a few times and get the same problem.
I then get the idea of using the other SLI slot. I figure it wont make a difference but for the sake of trying EVERYTHING i go for it...bam it works fine for the backup card, i try swapin in the real card, it works fine for that.....wtf o_O
damn i hope i dont hvae to buy a new mobo down the line if the other PCI slot goes out. Not to keen on draining the H20 system anytime soon. I'm hoping down the road that it turns out to be one of those mysterious computer errors that just fix themselves after you leave it alone for a while.
