odd new behavior on x2 4400 socket 939
Isurus
this behavior started happening around when i installed xfire though im not sure if it's directly related. i uninstalled xfire and it's still happening.
what's going on is ill have firefox or maybe another program open, and i notice my pc is being sluggish. if i CTRL ALT DEL, i can see there are two processes for one program. one will be running around 40-50% (taking up all of almost one core), and the other at around 0-3% (which you would expect)... i close the high percentage ones, and firefox stays running. so ive killed the extra process, but where the hell is it coming from and how do i prevent it from happening further?
is it a virus? if you think so then ill try nod32 but other than that idea, i cant think of any reason why this is happening, how it started, or exactly when except it started about 4-5 days ago.
did you install amd dual core optimizer? or the dual core drivers.... might fix it
i used the dual core optimizer, i believe yes. there was also a couple other tricks that i learned on these forums that i tried as well.
usually ill see 2 of firefox, just today i saw 2 of wuauclt.exe (though one went away on its own).
the 2 firefox processes are both at 0-1% so thats fine but sometimes one will go to 50% and i havent tracked down why.
wuauclt.exe is something to do with Windows Automatic Update.
firefox running at 50% might be an extension doing something dirty. Check to make sure you don't have any extentions running that you didn't install.
found out what it is i think. some kinda lowlevel spyware shit
http://groups.google.fr/group/24hou...read/thread/3ed0eea592c3012b/b5bab3b1a765e0b1
basically it makes shortcuts for your programs that instead of going to the original places, will go to c:\program files\***\data\resources\" so... it makes these fake little shortcuts under data\resources\ and it has 4 EXEs under c:\ that you'll need to delete.
apparently this just started happening to people around the same time it did for me as well. the solution is to the delete the 4 EXEs under c:\
>Besides Dllhosts32.exe are Dllhost32.exe, Dotnetfx.exe,
>Interop.shell.dll and Op32.exe files you need to remove.
These files BTW are easy to find they are all on the Root of the C:
drive Dated 9/4/06
not sure how i got infected with it, but it may be related to ebay? i have been going there recently.
