Odd.. my Keyboard/Mouse dont work anymore
Zallek
Heya, well, I was took apart my pc and was cleaning it, and then put it back together and now when it boots into windows the keyboard and mouse dont work. The lights on them (the laser on the mouse and the keyboard lights) turn on up until windows starts loading, and then they shut off like normal, except they dont come back on. My USB drive I have still works, but my mouse and keyboard doesnt... Anyone have any ideas as to what may of happened?
System in sig.
Thanks in advance.
are your mouse/keyboard USB or ps2?
Did your clock reset when you put it back together?
Can you access bios?
I'm leaning towards somehow you disabled keyboard/mouse support in your bios options.. atleast that'd be the first thing i'd check.
Try plugging them in usb or ps2 if you dont have them in, and a restart or 2 wouldn't hurt anyone:D
good luck
They're USB, which is why I was confused why they stopped working since my usb drive works. I checked the bios and everything was enabled still, but the bios clock was set at december of 02. Not sure why.. But it was all apart for 2 or 3 days.. /shrug.
Anyhow, I restarted 4 or 5 times, then I ran to my other comp and posted this question, came back, and now they work as Im using them to type this post.. Not sure what happened, but it all works again. Thanks for the attempted help though :D lol
You may have plugged them into different ports than they were in before.
Windows will detect new hardware plugged in and reinstall drivers when this happens (unless they had already been in that port).
Until the drivers are installed again the devices are unlikely to work as you found.
ps
You dont always see prompts for drivers on usb devices if they have previously been installed on your system.
