Not so long ago, I returned from college and set my computer up. When I turned it on, I hadn't yet plugged in my USB keyboard, so I got the standard "No Keyboard" error. I plugged it in, hit F1 and booted up. My keyboard, however, didn't work at the log in screen because I had ( and I realized this later) plugged it into the wrong USB port so I guess Windows didn't know what it was. So I turned the computer off using my power button to restart it. When it turned on, however, I got the "No Keyboard" error. I checked, and my keyboard was indeed plugged in. I tried every USB port I had, and none of them worked. I took it to a LAN party with me the next day and asked my friend. He messed around with my speaker jumpers, and voila, it booted up. I didn't get how that worked, but I didn't really care. A few days after the LP, I turned my computer off using the power button while I was in Windows (nothing was responding, so I just went for the quick solution.) When I turned it back on, I got the error again. So, I cleared the CMOS and that didn't work, so I moved around the jumpers that were behind my USB port on the motherboard, and it worked. The same thing happened again at another LP, and I did the same thing to fix it, and it worked. It happened again at the same LP, and I did the jumper thing, but this time it didn't work. I borrowed someone's PS/2 keyboard, and that one worked. I was reinstalling Windows at the time, so I finished that, and lo and behold my keyboard worked again. It happened a 4th time a couple days ago, and this time the jumpers didn't fix it. So, remembering that my friend's PS/2 keyboard worked, I got the adapter for my USB keyboard and it worked. Now, my question...what could cause my keyboard to stop working when I turn my computer off manually without shutting down Windows? I had turned it off that way several times before the first time this happened, and everything was fine. Is it possible that flashing my BIOS might help?
