- Oct 13, 2003
This only seems to happen in one game, and it appears to be solely heat related. After playing Team Fortress 2 for +/- 30 minutes the game will lock and both of my monitors will go to an image of a blank white/offwhite screen with jagged lines. The reason i say its temp related is i can open up the catalyst control center and ramp my fan up to 70% and it will run hours on end no issue.... The drivers only ramp the card up from the standard running 35% to about 45% and no higher...the temp at that speed usually(at full load) stays in the 68-70c range...but at the 70% when i set it myself, the temps stay around 55-60 fluctuating around a bit... In other games, the temps go just as high but dont lock up, but just this one... im completely lost....if anyone has any suggestions id much appreciate it
System info
6 gigs corsair dominator stock clock speed
i7-920 stock clock speed
abit p6td deluxe
xfx 4890 at stock clock speeds
and two samsung 245bw lcds...
System info
abit p6td deluxe
