rodneycubed
- Nov 30, 2007
Hi, My home network has been running like the top portion of this picture for a while, but whenever i plug my pc directly into the router it doesn't work.
2 things happen, the lan port on the router blinks slowly (1 sec on, 1 sec off) and the pc doesn't recognize that an ethernet cable is attached. I am certain that the ports are working because my laptop can get internet fine when I plug it directly into it. Also, the NIC on the PC is working (i.e. not physically broken) because it can get internet if i plug it into a switch that is connected to the router :/
I have a WRT54G v3 which is running dd-wrt. I have reset it a couple of times. If anyone knowledgeable on this subject could help me with my peculiar problem, it would be much appreciated. :3
