candy76man
- Jun 9, 2003
I have windows7 home 64bit on my system that has a MSI p55 mobo. the mobo has two realtek network adapters built in. I recently installed windows and everything worked fine but after roxio 10 updated itself I suddenly have no internet whenever I restart the system. The internet starts working again if I swap the rg6 cable to the other network adapter or if I go in and disable and re enable the adapter it's plugged into at the time so I it seems something is preventing the network adapter from connecting to my router on startup.
Any ideas on how to approach this??
I have disabled everything except my av program in the startup tab and I have installed the latest network adapter drivers from realtek. I will see if I can uninstall the roxio update but I'm not sure if thats possible. I also may try a rollback of the system and see if that clears it up but I'm hopeing someone has seen this problem and could help.
I'm not sure the roxio update caused the problem but that is the last major change before this problem showed up so..
