Odd ASROCK 939Dual-SATA2 question
Cabezone
So the board supports running 2 vid cards at once. With a X2, do you think it's possible to run 2 instances of a game with 2 nic cards installed and LAN them? I'm not sure if a game would be able to recognize the different LAN cards as two seperate systems.
I ask because I plan on getting a second monitor with my PCIE card and have a broke ass friend who'd like to be able to LAN with us. This seems like it could be an intersting way to let him in on the action.
If you install a 2nd NIC maybe if the game will allow you to choose the IP..
But then you have the problem of 2 input devices that would have to fight for the system.
How about you tell your friend to get a job.. Until then he can drool over your system.
That makes zero sense. How are you going to run the same instance of a game simultaneously on the same system. Even if you can find a way to do it, for instance, you can run two copies of Star Wars Galaxies at the same time in windowed mode on the same system, albeit pathetically slow, how do you intend to make the game pick one video card over the other? Maybe some weird Linux thing, but it seems it would be more trouble then it would be worth...
Well had you actually read my post you'd see what motherboard and chip I am using. My mobo can run 2 vid cards simultaniously and I have an X2 so I could run a game on each core.
In any case, I was asking the question for people that might know the answer to it, not someone who aparantly knows less than I do about it.
The main hurdle you would have to jump through is how to get Windows to deal with two mice and two keyboards. In my experience it just won't happen at all. I know of no way to map a second mouse and keyboard to a second monitor. Their may be a way to do it, but I have never heard of it (even in linux).
Lyquist
for what its worth, i know exactly what the board is capable of. I'm researching it now for a possible pet project. The question remains, assuming you can accurately run the game on each core, how do you plan on having the games choose the correct video card to run on?
I han't really thought too far into it, I was going to mess around with it when I get my PCIE card next month. I mostly asked just to hear people's ideas.
meatycheesyboy said:
Just found this which is kind of intersting but getting a little bit off topic.
http://www.aldenassociates.net/ProductInfo/Duet Savings Warranty.pdf
*edit*
If what I'm reading there is correct, you would need their software which appears to be tuned to those particular motherboards.
If I recall correctly, Windows XP does not equally balance two seperate desktops natively, or else its a feature of the graphics drivers. Your options would be to mirror the two desktops, or do an extended desktop to the second monitor. In this case you would not be able to run the game simultaneously unless it supports windowed mode. In Windowed mode you may be limited somewhat in what games support that mode, though I think that there are quite a few (i never bother running in windowed mode myself). Another problem, without an external application, is the GAMES would need to be able to select from the multiple video cards. I don't think there are any that do, though I could be mistaken.
The multiple inputs would be an issue too, unless it comes in a software package like the quoted contraption. I would have to double check the multiple inputs. My shuttle can run the onboard and agp graphics at the same time too i believe...i'll fire it up tomorrow and double check (i disabled it after I installed my old Ti4600.
